Firebird guys w/ headlight motor probs
Old Mar 15, 2003 | 10:12 AM
Dave 96TA's Avatar
Dont these two items look very similar...notice the mounting holes even. With a little wiring they might be an alternative to our headlight motors. Best part is - they're $25!
Here's a stock driver's side headlight motor:
http://store3.yimg.com/I/dpstore_1732_7595002
Here's the motor I found:
http://www.botparts.com/popup_image.php?pID=217
Interesting! And here's a link to the technical details about that motor:
http://www.botparts.com/product_info...roducts_id=217
Anyone care to try it out?? Theres also a matching motor for the other headlight.
Old Mar 15, 2003 | 11:00 AM
Fuels94TA's Avatar
Link to second motor, or tech link doesn't work. I like to see what your talking about. Did you switch to a different motor to fix the problem?
Vinny
Old Mar 15, 2003 | 11:25 AM
Dave 96TA's Avatar
Doh it looks like the site is currently down for maintenence. That stinks. Check back later I'm sure it will come back up.
As far as I can tell, the only thing you'd lose by moving to these motors is the manual **** that the stockers have. The motors are $25, the waterproof electrical connectors are $2.50 (bottom of page), and then a female GM weatherpak to mate with the factory plug (try rockauto.com) and you're set. No permanent modification to your car required!
Brake_L8
Jan 20, 2015 09:44 AM
Injuneer
Advanced Tech
Jan 15, 2015 02:49 PM
CaRParts102
Dec 6, 2014 08:45 AM
Red97LT1
Aug 7, 2002 05:45 PM
