Are 12.6xx's respectable times for bolt-on only LT1's?
Just wondering if running in the 12.6xx's with nothing more than bolt-ons is respectable? That means stock cam, stock heads, stock shortblock and no power adders. Also given the car is 3700 LBS should be taken in for account.
Weld Draglights 15x3.5 skinnies in front, 15x8 26x10.5x15 E.T. Streets in the rear. GM Motive 3.73 Gears.
BMR- Driveshaft Loop, Boxed SFC's, Tubular LCA's, Relocating Brackets. Drag Air Bag, V6 Springs in Rear. Front Sway Bar removed and spare tire and jack.
2800 10" TCI Conveter, TransGo Shift Kit, Summit Tranny Cooler. LS1 Aluminum DS.
1.6 Summit RR's, LT1 Edit.
Hooker Shortys Ceramic coated, 3" Exhaust to 3" cut-out. Flowmaster Y-Pipe.
Click on TA in my sig for the little items.
I try to run them when I only go to the track. Sometimes they are on when I go to work the morning before. They are not terrible, I take the interstate at 70 MPH and go around curves with them. I do however not try to drive them as say my stock 245/50/16 tires
Summit has the 15x3.5 Weld Draglights for $114.95x2
Pep Boys has the tires for $28.99x2 165R15
Mr Gasket 5/16 Spacers a pair $11.95 from Summit
Auto Zone 12MMx1.5 Closed W/washer $1.29 Each
I havent seen any LT1's run 11.xx's in bolt-on form here in Texas. No in Lousiana I have heard of one- Frank!
CARiD
Dec 26, 2014 04:20 AM
Hurin
Dec 13, 2014 07:38 PM
Z28Wilson
Aug 1, 2002 04:27 PM
GOATCRAZY
20
Jul 17, 2002 06:06 PM
