Injector size for a 383 solid roller
Old Mar 16, 2003 | 07:36 AM
FASTFATBOY's Avatar
I am building a 383 solid roller engine, with heads that flow 310 cfm@650, solid roller 250/260@050, 110 LSA. 11.5 to 1 compression,36 lb seem to be at the limit doing an 80% duty cycle. are 42lb SVO too big? Can the on time be turned down enough to work on a street driven car in closed loop? I am stuck on this issue.
David
Old Mar 16, 2003 | 08:52 AM
rskrause's Avatar
Moderator
42# inectors are definitely not too big.
Rich Krause
Old Mar 16, 2003 | 01:34 PM
Mindgame's Avatar
42# injectors should support close to 675 hp depending on your actual bsfc. Peak bsfc for my motor was .45. Some engines are bigger pigs than others, alot of which I've found to be a product of the cylinder head itself.... a much bigger deal on "wet" applications.
-Mindgame
Old Mar 16, 2003 | 01:39 PM
kmook's Avatar
Advanced Tech Moderator
If i can run 72#s on the street you can run 42s for sure, and i think 42s would be good for your setup. And Please post non-advanced technical questions in a regular technical forum. Thank you.
Old Mar 16, 2003 | 03:12 PM
Josh-'04 GTO's Avatar
Here is a decent calculator for you:
http://www.smokemup.com/auto_math/fuel_injector.php
You should do a search, injector sizing gets covered every few days or so.
Old Mar 19, 2003 | 08:09 PM
redygo's Avatar
i used 36# and i went static
cmyname1
Feb 19, 2015 08:38 PM
95chwagon
Jan 13, 2015 09:19 PM
Wicked
Jul 25, 2002 04:19 PM
Ed95Pont
Jul 23, 2002 08:26 AM
