anyone running a crane 222/230 cam?
Old Mar 16, 2003 | 02:15 AM
96LT14u2Nv's Avatar
i just bought this cam. just wondered if anyone else was running it and some of the results u got. if u have some video or sound clips, that would be awesome.
Old Mar 16, 2003 | 06:26 AM
badass383's Avatar
I have those duration numbers but my lift at the cam is 339I & 352e. With the 1.6's that gives me 542I & 563E. I use this with a blower so I'm not sure you can equate my results to yours. Also to help keep vacuum up, I'm running a 114deg overlap and gapless rings. So my idle is pretty tame. I'm not a computer guru so I don't know how to post stuff here but then I don't have any to post anyway. My new / used rear isn't ready yet. Once the 10 bolt is done I should get to the 10's. With the susp. mods and 11" rims in the back (I hope).
Kinda short on funds right now. Good luck with the 9" your braver than I am. The 8.5" 10 bolt is an easy swap. That's why I got mine at the JY for $40.00.
Be sure to get the heavy duty chain kit PN 12370835. I liked mine, went in easy and you'll notice a lot of end play in the cam until you get the gear on, don't let that scare you. It's normal. Check out the old one before you remove it.
See ya
oldschool
Feb 9, 2016 09:21 PM
thenewkid
Nov 27, 2014 09:41 AM
Don 97 SS
Jul 11, 2005 08:50 AM
IgorT.455/406
Feb 1, 2005 06:18 AM
IgorT.455/406
Jun 4, 2003 03:32 AM
