opti
opti
my car will not start all it will do is turn over had a lot of rain a lot of moisture on the engine could it be that it got on my opti it is not vented it is a 93 z with 102,690 orginal on the opti sounds like it might backfire what do you think.
how long has it been since your car was started. Just to rule out the getting wet the same thing happend to me about 5 months ago i replaced the opti, coil, and some other stuff but nothing worked. it was also raining really bad when my went south. finally i got a fuel pressure guage and it was my pump. just before you go and spend 3 to 4 hundred bucks on a opti test every thing. the bad part about mine i could still hear the pump come on but didnt have enough psi to crank it. sorry to run on but i spent a lot of money that i didnt need to. good luck!
Formula Steve
Sep 19, 2023 08:31 AM
