healthy RPM range???
Old Mar 15, 2003 | 10:43 PM
bachehbad's Avatar
Ok i just wanted to know what are some healthy RPM ranges??
here is what i ussualy cruise at
1st gear 1000-2000RPM
2nd gear 1200-2000RPM
3rd gear 1400-2100RPM
4th gear 1500-2100RPM
5th gear 1600-2100RPM
6th gear 1800-2200RPM
am i staying too low in the RPM band? im just afraid im putting stress on my engine, even at low RPM's with just a little touch on the gas the car feels like it has all the power it needs... is this ok for my car??? or should i bring up these RPM's??? Also if anyone could attach a dyno chart of a stock LT1 on a dyno it would be much apreciated.
Old Mar 15, 2003 | 10:52 PM
BPS's Avatar
BPS
I normally drive my m6 in the 1800-3500 range, I don't often get to 5th or 6th.
Old Mar 15, 2003 | 10:57 PM
bachehbad's Avatar
think i'll get carbon build up with RPM's tht low??
cause i barely touch the gas at all.... like maybe 1/10 throttle at most and car picks up well. 1800 RPM my car has too much power, more than i need for cruising. in lower gears anyways... in 6th i ussualy cruise at 2000RPM so around 120km/h
Old Mar 15, 2003 | 11:25 PM
smokindastangs's Avatar
nahh...you should be fine. That is just about exactly what I run on mine. Unless your engine is loading up/ bogging down I would not worry about it.
Old Mar 16, 2003 | 09:03 AM
bachehbad's Avatar
anyone else have input?!?
Old Mar 16, 2003 | 09:42 AM
anasazi's Avatar
drive it like you stole it once and awhile, you won't have any problems.
Old Mar 16, 2003 | 09:48 AM
bachehbad's Avatar
anasazi i do drive it like i stole it more than once in a while :P
But when i'm low inc ash i like to save on gas, but i would rather spend a few extra bucks and not damage my engine!!!
Old Mar 16, 2003 | 10:42 AM
Redstar's Avatar
i like shiftting around 3ish, sounds so good
Old Mar 16, 2003 | 10:45 AM
joeSS97's Avatar
5.8 K every shift
Old Mar 16, 2003 | 10:49 AM
Larnach's Avatar
My driving habits... on a full tank... I have only 86 miles so far and its getting down to the 3/4 mark on the gauge!
And gas is $2.39 a gallon here.
Daluchman1974
Sep 11, 2015 06:12 AM
damnyankee36
Sep 9, 2015 07:06 PM
Greg88
Aug 24, 2015 07:59 AM
Aug 7, 2015 08:52 AM
Z28amustangklr
Jul 18, 2015 11:05 AM
