I lost one of the clips that hold fuel injectors in place
You know the little metal clip that slides in to lock the injectors in. Where can I get one or do have to buy a whole set? Do I have to have it? Any help would be great. Thanks Alan
Look right in that same area on the lip of the intake it is probably resting right there. That's where mine was at least, who knows how long it was sitting there. It didn't appear too necessary to me, the injector remained snug fit without it.
unless your having some kind of a problem, i wouldn't worry about it until you have to pull the fuel rail. with the o-rings on the injectors, they tend to seal up pretty tightly. the clips are mainly just to hold it in place while your trying to get it together. but you should be able to get them really, really cheap if you need some new ones.
yea, well my fuel rail and intake are off the car.
I took off one the last injector on one side to compare it to the new ones and didn't notice that it slid off the rail.
oh well I guess it will be ok.
i have my intake off and had the rail no where near the car. i was walling around with it with one injector out (fist time i have ever pulled an injector before). I didn't notice it was loose and it sild off. I found one, Max93 is kind enough to send me one. Thanks guys for the input. And Max, you da man! thanks for the clip. Alan
Jul 4, 2005 05:00 PM
sleeperZ96BT
Jul 24, 2002 11:28 AM
