94 LT-1 wiring codes for swapping into a 94 Blazer
Old Mar 16, 2003 | 10:02 AM
94FlamdS10Blazr's Avatar
Ok I got a 94 LT1 Caprice motor and I need help with the wiring codes for the motor. More to the point, I need to know what wires go threw the firewall so I can hook em up to the blazers stock harness. Also the blazers speedo computer is inside and the Caprices is built into the computer right? I got 3 harnesses left over from my stock blazer computer that were on the computer that went to it and the stock speedo computer
it was $1,114 for the motor, harness, computer, starter, compressor, power steering pump, and alternator . The other $1,100 was a tq converter, motor mounts, conversion headers, shift kit, Granatelli MAF, K&N FIPK, and MSD wires. Sounds good? If anybody needs this place locally in Miss , or to ship out which they do, Ill hook you up with the number
Old Mar 16, 2003 | 10:58 AM
also what will happen if I take off the AIR system and the back EGR pipe from the pass side header and block off the plate on the motor?
Sergio
Jan 27, 2016 04:27 PM
89 iroc zl1
3rd Gen / L98 Engine Tech
Jan 14, 2015 02:18 AM
cmdeshon
Jan 4, 2015 11:15 AM
sskevinm
Dec 18, 2014 11:16 AM
Jul 4, 2005 05:00 PM
