Low coolant light....
Old Apr 11, 2003 | 10:59 AM
James3219's Avatar
Question Low coolant light....
For the past month or so my low coolant light will come on for no reason. I have plenty of coolant in the radiator and over fill tank. What could be causing the light to come on?
Old Apr 11, 2003 | 11:14 AM
norcalstreet's Avatar
Aside from the obvious like bleeding air out of the system and checking for leaks at hoses I would say a bad sensor. You can disconnect the sensor and the problem should go away. That, of course, won't solve your problem if it actually is related to coolant level. Also, a bad radiator cap will let air leak into the system.
Old Apr 11, 2003 | 11:17 AM
James3219's Avatar
Where is the sensor at, I have ruled out most everything else.
Old Apr 11, 2003 | 11:18 AM
VegasZ's Avatar
I had this same problem. Was a bad coolant level sensor. Common problem. It is on the radiator right next to the battery. A new one was $23 from www.gmpartsdirect.com. Very easy install. If you disconnect it, the light will go out.
Old Apr 11, 2003 | 11:25 AM
teke184's Avatar
i've got mine unplugged,
one of these days i'm going to pull it out and try cleaning it, i was told if you clean it sometimes it functions properly again...cheaper than buying a new one anyway...
Old Apr 11, 2003 | 11:28 AM
James3219's Avatar
Thanks. I guess I will order one.
Old Apr 11, 2003 | 11:29 AM
94T56T-TOPDREAM's Avatar
GO TO SHOEBOX'S WEBSITE http://csce.uark.edu/~jgbertr/rb/4th_gen_tech1.html
HE SHOWS WHERE IT IS AND ALSO HAS LOTS OF OTHER GOOD STUFF ON THERE
Old Apr 11, 2003 | 03:09 PM
Terran2k's Avatar
http://www.carparts.com/parts/sample...rtnum=NONE&dc=
at carparts.com i see a coolant level sensor for $8.05, alot cheaper than the $23. check the part # i suppose.
Old Apr 11, 2003 | 09:47 PM
James3219's Avatar
Thanks guys, and thanks for the link to shoebox's page. He is a very helpful person.
blac94Z
Feb 15, 2021 09:43 PM
calaban
May 18, 2020 06:43 PM
Fatdog2
Apr 27, 2015 10:32 PM
AlaskaZ28
Jan 1, 2015 12:30 PM
