Bad vibes while slipping clutch
Old Apr 10, 2003 | 05:37 PM
MZK4252's Avatar
I just had my engine rebuilt and internally balanced. My clutch (Centerforce DF, I know, I know...) was slipping before the rebuild but I decided to see if I could hold out on it. I had my flywheel resurfaced, but used the stock flywheel.
So, the problem is that I get huge vibrations when I slip the clutch around 2-3k. Since I had the rotating assembly internally balanced, could there be an imbalance from the previously balanced flywheel? Or is my clutch just sucking?
I am thinking that I'm making about 350 RWHP with my setup, if that makes any difference.
Any help would be greatly appreciated.
Old Apr 10, 2003 | 06:19 PM
z28Power's Avatar
vibrations on the whole car, or just the tranny? Could be the tranny mount is shot, they're cheap and easy to replace.
Old Apr 10, 2003 | 06:20 PM
MZK4252's Avatar
It's coming from the engine/tranny, but its so violent it shakes the whole car.
The trans mount was fine when I had everything apart, and it never did this before the rebuild.
Old Apr 10, 2003 | 06:44 PM
QUASARBLUEZ28's Avatar
Going on a limb here but.... pilot bushing/bearing.
Old Apr 10, 2003 | 07:17 PM
IRABuss's Avatar
sounds like a little bit of chatter. prolly since you had the fly wheel surfaced. My stage 3 will do the same thing. it vibrates so bad when you try to slip the clutch, the pass. seat will move back and forth. Drop it a few good times at the track, it will go away
blkWidow
Apr 21, 2015 01:56 PM
HectorM52
Jan 30, 2015 11:08 PM
IgorT.455/406
Jun 4, 2003 03:32 AM
Chrisdude
Aug 14, 2002 06:30 PM
wytblur
Aug 5, 2002 02:10 PM
