Cam Dowel Pin Length?? CC306
Old Apr 10, 2003 | 12:06 PM
SVT Killer LV's Avatar
I am putting a 306 in my car and realized that the cams pins and optis hate each other. I have a 94 Z28 with a NON vented opti and a new CC306. Do I have to pull that pin out and put my stocker in??? Or am I cool?
Old Apr 10, 2003 | 12:11 PM
Don 97 SS's Avatar
I just put a new DynaSpark opti on my 97. AS I recall DynaSpark states that the Max height is .620" (face of cam to tip of dowel). This is a little shorter than the GM specs. I had to grind the dowel down to get it within specs.
Old Apr 10, 2003 | 12:18 PM
quicksilver97ta's Avatar
Whats the GM specs? I want to check my XE 230/236 before install.
Old Apr 10, 2003 | 12:33 PM
what is the length for -94 and then 95+
Old Apr 10, 2003 | 12:35 PM
snksknr94's Avatar
I didn't have to do anything to the pin when I put the cam in my car. If you have a vented opti, you have to pull the pin out a bit. You should be fine.
Old Apr 10, 2003 | 02:08 PM
96blackbeast's Avatar
why don't you measure it against the stocker?
Old Apr 10, 2003 | 02:45 PM
Don 97 SS's Avatar
I believe that GM says .675" is max. on 95+. But someone needs to verify this.
I thought it was interesting that DynaSpark wants no more than .620".
Old Apr 10, 2003 | 03:31 PM
cause I was just wondering
oldschool
Feb 9, 2016 09:21 PM
Midnight_Z
Parts Wanted
Apr 3, 2015 12:46 AM
StansZ28
Feb 19, 2015 07:39 AM
chuyz28
Feb 19, 2015 12:50 AM
The Seer
Classic Engine Tech
Nov 26, 2014 05:55 PM
