Waterpump shot? (Shoebox?)
Old Apr 11, 2003 | 06:51 PM
mrz28M6's Avatar
Well i am getting a loud upnoxious noise at idle and while i am driving but mostly at idle, i thought it was the alternator's bearings shot, so i replaced the alternator still makes the damn noise, the only other things i can think of is the belt which i didnt replace because they didnt have one in stock or the waterpump. Any help would be greatly appreciated.
dustin
Old Apr 11, 2003 | 07:04 PM
treyZ28's Avatar
From: looking for a flow bench so Brook and I can race
Re: Waterpump shot? (Shoebox?)
dustin
look under the car-
the water pump has a "weep" hole that will leak when the bearings are worn. Unfortunatly it will leak on the optispark so make sure you change it right away if you see antifreeze residue/liquid antifreeze
The waterpump is also driven by the timing chain
Make sure its not a "normal" car sound or valvetrain noice or even an exhuast leak
Old Apr 11, 2003 | 07:56 PM
The water pump can definitely make some noise if the bearings are going, but it is real hard to tell with it mechanically driven. Like Trey said, it usually will begin to leak when the bearings are going out.
Just to rule out anything else, try taking your serpentine belt off and see if you still have the noise.
Formula Steve
Sep 19, 2023 08:31 AM
68camaroboltz
Oct 5, 2015 11:56 PM
Sep 18, 2015 03:46 PM
NewsBot
Sep 15, 2015 11:53 AM
damnyankee36
Sep 9, 2015 07:06 PM
