What gears for M6 with heads/cam???
Oops forgot to mention it will be a daily driver.
As for 4.10's i know they are everyones favorite for a M6. Yet i just dont want to run out of every gear in less than a second. I still need for 1st and 2nd to be useable.
And i dont really want to be in 5th halfway down the track :P
maybe i answered my own question there. But then again i dont know how 3.73's act with this cam.
I am going with 3.73 gears...although 4.10's are probably the best, I to use mine as a daily driver during the warm weather and I share the same feelings as not wanting to be in 5th gear running the quarter. That is just how I feel about it.
3.73's sound good to me.
1997rblckSS i feel the same way. Though i have a seperate question for you. How do you like that clutch? How does it feel, grab, and any chatter or vibration from it?
Thanks!
Thanks!
Thanks!
Thanks!
I'd say 4.10s for that cam. 4.10s aren't the best gears for all M6 cars like everyone seems to say. You have to match your gears to your cam and your powerband. I really like my 3.73s; makes the car more driveable with the cam I have and at little sacrifice to gas mileage.
I've had 3.73s in my car for about 5 years and I have been pleased. They provide a small but noticeable change from the oem 3.42s. 6th gear is now usable at lower speeds and 1st gear is just right. I know many friends with 4.10s and they are happy, too.
Much of this gear selection business is just personal preferrance. I would think 3.90s would be great, but I don't feel in the mood or have the coin to change the diff.
I think of the T56 as a 4-speed with two overdrive gears. Thought of that way, where 5th and 6th are used for cruising and highway and 1-4 for other driving, I'd say 3.73's. If you want to drive it like a 5-speed plus one OD gear, get the 4.10's. Makes sense? At least it does to me. And that's actually the origin of the transmission and how the gears were selected.
Maybe a better way to think of it: a typical LT1 doesn't need a super low first gear, like you get with 4.10's. If 1-5th were closer together, with a higher first first and a lower 5th, then you could use 4.10's. But as it is, 4.10's make 1st pretty useless on street tires.
Just my $0.02
Rich Krause
Just my $0.02
Rich Krause
I got a CC306 (similar to ur cam) .. and i first had it with my stock rear (3.42s) it was a nightmare to drive ... it was slow, sluggish and frustrating to drive around town ...
then i got a 12bolt with 3.73s and it felt SO much better around town ... a set of 4.10s are going in today ... i think any big cam needs low gears (3.90s or 4.10s) u need to have the cam in its power band . and since u can rev higher with a bigger cam, a lower gear suites ur car and gives u the same range, only a bit higher in the rpm band
4.10s and a stock cam wont go together cuz ur car runs out of breath way too quick
about the track ... im worried about running out of gear on 26" slicks on the bottle ... if that happenes ... i'll get 28" slicks and problems solved
ok, someone said that with the 4.10s, they are hitting the top of 4th gear aroudn 118mph.
with heads/cam (big cam) i want the top of 4th to hit 130-140 range..........is there a gear calculator to figure out what i want?
keep in mind im not really interested in track times.
if i make a pull on the highway up to 150-160.....is 5th gear just gonna fall on its face? or will it accelerate like an extra gear, instead of an overdrive?
