58mm tb on a4 without programming?
Old Apr 10, 2003 | 04:52 PM
Kory 88 Iroc Lt-1's Avatar
I have a holley 58mm tb I want to put on my car. I plan on getting the car dyno tuned in the next month or two. I have heard that the 58mm will cause low line pressure problems in a 4l60e if the computer ins't programmed for it. I have a transgo shift kit set up with 3 washers. Will this make any differance? i don't want to burn up the trans.
Any thoughts?
Thanks,
Kory
Old Apr 10, 2003 | 05:02 PM
triumph's Avatar
I may run a bit crappy with out programing for a bigger TB A/F ratio etc... You bumped up your line pressure with the shift kit so you should not have any worries there i suggest that you either use the shift kit or the computer to up the line pressure DO NOT USE BOTH! I did and blew a seal in the trans and fried the clutch packs. Good luck . Steven
Old Apr 10, 2003 | 05:06 PM
Thanks for the input.
Does anyone else have an opinion?
I think I will probably put it on but I would like a little more input.
Thanks,
Kory
Old Apr 10, 2003 | 05:17 PM
anaik's Avatar
I tried a 52mm, with a Transgo, and it caused part throttle shifting problems. Most people don't have problems with a 52.
Old Apr 10, 2003 | 06:37 PM
Brent94Z's Avatar
Super Moderator
I gotta disagree with the 58mm causing problems with the running of the car other than A4 shifting. The PCM should correct A/F ratio regardless of what size TB you have to my knowledge.
You do run a risk by running the 58mm throttle body without programming but, IMO, on an F-Body the risk is minimal. I ran a 58mm throttle body on my A4 Vortech supercharged 94Z for several years with NO programming changes! The shifts were weak but my tranny didn't immediately burn up I had the car to the track several times and drove it around town quite a bit. I think I put around 25k miles on the car with the 58mm throttle body and no adjustment in PCM programming. I did, however, have a Trans Go shift kit installed with 2 washers and I'm sure that helped some.
Old Apr 10, 2003 | 06:54 PM
I have three washers in mine. I think that I'll try it. I can always go back to stock if it seems too soft.
Kory
Old Apr 10, 2003 | 07:29 PM
IRABuss's Avatar
another thing to look at it the intake port size. If your intake is not ported to 58mm..there is not a lot of reason to go with the 58, unless of course, you plan on porting it.
Old Apr 10, 2003 | 07:51 PM
I ported it a while back when I had the heads off.
Kory
Old Apr 10, 2003 | 11:34 PM
Dan K's Avatar
OK, what would changing tb size affect that would necessitate programming changes?
I don't quite understand why a larger tb would need any change in line pressure or anything.
Old Apr 11, 2003 | 12:14 AM
WS6T3RROR's Avatar
yeah i wonder too what does a bigger tb have to do with the trans? i noticed no difference when i went to a ported stocker from lpe.
Old Apr 11, 2003 | 12:28 AM
anaik's Avatar
The 4L60E shifts according to vehicle speed and throttle position sensor. With a bigger TB, the sensor will show less of an opening for a given speed, unless reprogrammed, and shift softer.
revrider
Cars Wanted
Apr 5, 2016 10:06 AM
truecontr3
Oct 11, 2015 09:30 AM
MDZ28
11
Sep 24, 2015 09:15 AM
marlar98
Sep 19, 2015 07:53 AM
whitehooptie
Aug 10, 2015 07:02 AM
