stock panhard bar vs aftermarket NON-adjustable bar??
Old Apr 10, 2003 | 08:44 PM
JTS95TA's Avatar
I just got a pair of 17x11 ZR1 wheels with nitto 315 35 17 tires. The wheels are in the 50mm offset so they sit perfectly flush with the fender. They look sweet however I can tell since my car is lowered that the rear end is slightly offset to the drivers side. A friend of mine has the same setup on his car but is running a BMR NON-adjustable panhard bar and his rear end seems perfectly even on both sides. My question is, are aftermarket non-adjustable panhard bars lengthened for lowered cars or something? Im asking because obviously they are cheap so if they are I can save a few bucks.
P.S. we both have same eibach pro kit.
Old Apr 10, 2003 | 09:19 PM
Each car is slightly individual. No way to tell if yours would do the same with the same product. Why not take his off and put it on your car and see if it is as perfect? If so, order one from BMR. If their quality control is good, your new bar should do the same.
Pretty sure replacement panhards rods are the same length as stock.
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
canbaufo
May 25, 2015 12:01 PM
MyShibbyZ28
Feb 14, 2015 12:05 PM
DubbyZ28Camaro
Aug 4, 2002 12:53 PM
