AC Problems...
How are you checking the pressure without the compressor running?
It will have to run to check both high and low side.
If you jump the low press. switch out the compressor will run.
Check pressure, if it is good, replace pressure switch.
Good Luck,
Michael
Good Luck,
Michael
Highlander
Sep 15, 2004 08:42 PM
