Help bad mis
Old Apr 11, 2003 | 01:34 PM
Bad T.A.R.A's Avatar
Help bad mis
Okay here is the deal. I have a high RPM mis and today I had a low RPM mis for just a second. When I down shift into second and WOT it stumbles bad but if I down shift into second and wait and second and then punch it it does better? If my coil is sort loose would that cause any problems? ANY advise. I have replace wire, plugs, coil...
Old Apr 11, 2003 | 01:39 PM
Rodrigues's Avatar
If you coil is "loose" tighten it, Try to explore other methods first, but those are classic signs of an opti. If it JUST had the high rpm miss I would say it was coil or plugs, but you mentioned the low rpm miss as well and stumbling. Seems like thats a classic sign...
Boss002
Jan 20, 2016 12:17 PM
HectorM52
Parts Wanted
Aug 8, 2015 08:12 PM
vwb11356
Jul 22, 2015 06:51 PM
colts0455
Jul 8, 2015 12:21 AM
colts0455
Jul 7, 2015 07:19 PM
