What kind of paint for 12 bolt?
Old Apr 10, 2003 | 11:55 AM
FireAm94's Avatar
I just received my Strange 12 bolt and am ready to paint it. What kind of paint did you guys use on your rears? How did it hold up? I know there was a thread on this a couple weeks ago (we need a different msg board search tool....something that will find partial matches!) but couldn't find it.
Thanx
Joe
Old Apr 10, 2003 | 12:28 PM
IDOXLR8's Avatar
I would high suggest getting the housing powder coated. I just had my 9-in housing powdercoated a week ago and it looks killer.
Old Apr 10, 2003 | 12:46 PM
atljar's Avatar
Powder coat would be killer, but will cost $75 or so i guess, and you cant do it yourself.
I would think some type of engine enamel would work well, with a few coats of clear over it to protect it. Dont forget a rustoelaum (Sp???) base coat.
Old Apr 10, 2003 | 12:49 PM
ShelbyZ28's Avatar
www.por-15.com
FireAm94's Avatar
Comon guys....just spent $2500.....paint please...hehe....unless you're making a donation to the 12 bolt powdercoat fund.
Joe
Old Apr 10, 2003 | 12:56 PM
ShelbyZ28's Avatar
Go to the Por-15 website I posted and look at the starter kit. It gives you everything you need to do the job for $15 including rubber gloves and paint brush. The amount they give you is pleny to do a rear end. This stuff is awesome and looks great. Its easy to apply and it will keep your rear end looking great forever.
Bryan
Old Apr 10, 2003 | 01:16 PM
FireAm94's Avatar
Just called em and he is finding a distributor in Alabama for me. I had posted seconds after you put that up....that was the stuff I was looking for.
Thanx
Joe
Old Apr 10, 2003 | 01:17 PM
Powder coat???? I personally would not recommend cooking your fully assembled Strange 12-bolt at 350degF....
Try the POR. When I got my Strange, I washed it off with TSP, and applied some black Rustoleum to the tubes, and a DupliColor "Hammertone" silver to the center section. Looked great, but now 3 years later, there are lots of signs of rust. Maybe some primer and a better grade paint would have lasted longer.
Strange, with paint
And another
Old Apr 10, 2003 | 01:20 PM
ShelbyZ28's Avatar
Thanx
Joe
No problem . Hope it works out for you. Good luck.
Bryan
Old Apr 10, 2003 | 10:38 PM
atljar's Avatar
No i def wouldnt put the rear in the oven assembled, lol.
The housing and axle tubes only, guess i shoulda been more specific.
Old Apr 10, 2003 | 10:55 PM
JSK333's Avatar
Hey Fred, if that rust gets to be too annoying, we can work out me picking up that rearend from you so you don't have to hurt your eyes.
I've never used POR15 but it sounds good. I used Engine Enamel on my brake calipers, which see a ton of dirt/dust, etc., plus high temps, and it has held up fine--if I had clearcoated them, I know they'd look even better.
Old Apr 11, 2003 | 12:20 AM
FireAm94's Avatar
I think that was understood
Joe
Old Apr 11, 2003 | 12:37 AM
atljar's Avatar
I hoped so, but you never know with some of the stuff i have read on this board...lol.
Old Apr 12, 2003 | 02:15 AM
NJLT1SS's Avatar
Go with the POR-15. I used it on my Strange 12 bolt back in November, and it works awesome. For 15 bucks, the starter kit will cover the entire rear and then some. I went right to the POR-15 headquarters, where their showroom is, since they are only located about 20 minutes form my house. I cleaned my housing with some Metal Prep, to get any grease off of the surface, let it dry a few hours, then put the first coat on. I let it dry overnight, then applied the second coat. After the second coat was dry that afternoon, I installed the rear. Just to let you know how durable the stuff is, I have jacked up my car several times from the rear, and the jack hasnt even made as much as a mark on it. If you go with the spray paint, you will be sorry, it will rust in time, depending on the climate and conditions you drive your car in. Go with the POR-15, you will kick yourself in the *** later if you dont.
Nick
Victor Lamb
Aug 26, 2017 02:52 PM
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
maybe2fast
Mar 16, 2015 09:45 AM
ddr698
Jan 9, 2015 10:05 AM
