pulling engine through top
Old Apr 9, 2003 | 10:11 PM
1FASASZ's Avatar
Question pulling engine through top
do i have to take the manifold off? how do you hook the cherry picker up to the block? do you have to take the ac radiator looking thing out?
Old Apr 21, 2003 | 01:04 AM
1FASASZ's Avatar
ttt
Old Apr 21, 2003 | 01:16 AM
nitrojunky's Avatar
Exhaust manifolds must be removed. They're best removed after the motor mounts, tranny, etc. are loose and the motor's on the cherry picker.
Buy a 'Happy Hooker' from TPIS (yes, that's the technical name); it will attatch the cherry picker to your intake manifold via the four surprisingly strong injector rail bolts.
I've removed the motor both with the compressor/radiator/ac condensor in and out; it's muuuch easier to remove with the radiator/compressor/radiator out, but then you have to charge the system.
calaban
May 18, 2020 06:43 PM
Gtpguy
Jan 26, 2015 04:50 PM
siguy
Nov 27, 2014 10:07 AM
Darth Xed
13
Jul 22, 2002 12:45 PM
Doug Harden
11
Jul 14, 2002 04:31 PM
