what are your 60ft times???? Help others with thiers!!!
Old Apr 10, 2003 | 04:14 PM
ramair96ws6's Avatar
and if you are so inclined what degree of pinion angle are you at , what do you have for suspension mods, and also what tire size and brand are you using
Thanks Steve
hopfully this thread will help other in thier quest of a better 60ft.
Old Apr 10, 2003 | 05:49 PM
darkangel95's Avatar
I know mine isn't that great but I figured I would throw in a stock time.
2.191---60'
Stock Suspension
245/50/16 Sumitomo HTRZ tires @ 30psi
Old Apr 10, 2003 | 06:02 PM
12SCNDZ's Avatar
Completely stock suspension, springs, shocks, control arm, and torque arm. Removed front sway bar. 4.10 gears. 3200 stall, 26x10.5x15 M/T ET Streets. Stock motor from throttle body to oil pan.
How about 1.73?
Old Apr 10, 2003 | 06:23 PM
Derrick Redd's Avatar
Best of 1.55. Mods in sig.
Old Apr 10, 2003 | 08:42 PM
Zepher's Avatar
Lakewood LCA's, Jamex Springs, Kumho Ecsta Supra 712 tires 275/40/17.
86 Trans Am 305 TPI 5 Speed, 3.42 gears, 2.03
96 Trans Am 350 LT1 6 Speed, 4.10 gears, 2.06
Both cars have the same suspension mods and were running the same wheels and tires.
Old Apr 10, 2003 | 08:47 PM
BOWTYDE's Avatar
I'm my sig. That isn't my best, but it got me my best time, I would have to look up my best. That is on stock tires.
Old Apr 11, 2003 | 03:53 AM
HungryT/A's Avatar
Completely stock worn out suspension, crappy 245/45/R16 Uniroyal tires with no thread left on them.
Result: 2.38 '60
Old Apr 11, 2003 | 05:18 AM
MyTMous's Avatar
best so far on 162,000 mile shocks (just got the new ones in), stock everything else but the engine, and getting traction for once.
2.01 60'
It will get better.
Old Apr 11, 2003 | 05:56 AM
Smokn '94 Z's Avatar
Lightbulb
1.64's on a stock suspension minus the new DMS Lowering springs.
Old Apr 11, 2003 | 05:57 AM
GhostZ's Avatar
1.92 on stock suspension and the good ole Pep Boys Futura's.
Old Apr 11, 2003 | 06:10 AM
rje's Avatar
rje
I Have 12 way QA1's up front,3 Way CC shocks out back, BMR trac-pak with 3 degs PA, BMR drag swaybar, and run 27x11.5x15 Hoosier QTP's. My best 60 ft is a 1.54, but I'll average around 1.56.
Randy
Old Apr 11, 2003 | 09:53 AM
Camaro SS's Avatar
Stock suspension front and rear......Front sway bar removed......Stock rear w/3.73's.......26" ET Streets
1.44 60' on motor
Old Apr 11, 2003 | 09:57 AM
ksmyss's Avatar
lakewood lower control arms, relocation brackest set to middle setting, bfg drag radials @ 25 psi, poly tourqe arm bushing, no front sway bar, 4.10 gears and leaving at 4000 rpm=1.88 60 ft spinning
Old Apr 11, 2003 | 03:00 PM
2slow4u's Avatar
1.88 60' Totally stock suspension, 2800 converter, 26x11.50x16 et streets!
Old Apr 11, 2003 | 04:39 PM
thanks for all the replies the reason i ask is I just bought a moser 12 bolt, 26x11.5x16 e.t. streets and a spohn trq arm. the car already has mac lca and mac panhard bar so hopefully ill be in the 1.5-1.7 range!!!
And I wanted to see what you guys had also so i could see what works and what doesnt. and ofcourse what pinion angle you were at so i could set mine : ) for test and tune tonight
im running tonight for the first time with this setup so ill post what i ran after tonight my current best is a 1.9 on nitto drags with a stock trq arm, with the mac lca and panhard bar
Thanks Steve
