Pulling Engine thru top: What did you do with POWER STEERING & A/C ? Alt Brkt stuck
Pulling out thru the top. I'm almost done, all the wiring's outta the way. I ended up breaking a couple of the brittle connectors
Not sure if they can be replaced
Anyways, What did you do with the power steering pump, and A/C Compressor? I need to put the PS pump somewhere so I can get the ALT bracket off...
What all needs to be off the front? Does the Balancer have to be offf?
When i pulled a motor out of a 94 camaro the only thing off of it was the headers and intake. When I reinstalled it I had everything put together, the only thing i left off was the electric water pump (the base was there though)
The plug you might be refering to is the knock sensor, it should come off if you squeeze both sides of it (I think it has flat spots on the outside where you need to squeeze) When you do that it should just pop right off.
We just disconnected both the powersteering pump and AC condensor and let them hang in the bay. We took the bracket right off.
By the way. Could you give me a description or take a pic of how the accessory bracket mounts to the block, how many, size, bolts etc? All I have left is a bunch of bolts and bracket...
If the connector is grey its for the knock sensor.
I guess I shoulda been more patient before I BROKE the knock sensor
Looks like it'll still stay stuck on though.
I'll try and get some pics/descriptinos of the brackets for ya later
AC condensor is OK, it's the Compressor I'm trying to get off, along w/ the power steering pump. Need to at least get the p/s pump outta the way to get the alt bracket off...
You did go thru the top right?
hell, if I had a cherry picker this ****'d prolly come out now
theres a bolt on the backside of the compressor that mounts it to the block. Also you can leave the acc. bracket on the block. I pulled my motor with all accessories still attached. put it in that way too.
Did you leave the A/C, and PS in the car when you pulled the engine?
How did you leave all the accessories on? Did you pull it straight forward and up and out? Or did you have to turn it 90*?
Originally posted by dobe
I am pulling mine out now also... should I leave the tranny hooked up or not?
