Hesitation at high revs and high speed
Car has been hesitating at approx 140-160kph and 4000+ rpm, doesn't want to hold revs very well and doesn't pull smoothly. Thought perhaps it was the optispark, but in neutral car revs smoothly all the way to redline. seems to only happen in 4th at high revs. Doesn't really feel like it's misfiring, more like something is slipping. Clutch pack in tranny maybe? Car is an A4 with 132,000 kms on it. Any body have similar problem?
This happened to me awhile back in park and neutral ran fine but in gear it hesistated and missed. My problem was dirt in my carburator. i took it apart and cleaned it out and took air compressor and blew all the holes out and then it ran perfect. But we are talking about two totally different things with carb and efi. Your injectors may be stopped up or check your fuel filter. Hope this helps.
