Devcon block repair
Old Apr 11, 2003 | 12:27 PM
Witherspoon's Avatar
Devcon block repair
I had a 396 stroker kit installed and the machine shop "hit water" when machining clearance for the crank. They used Devcon to repair the deep cut and didn't tell me about it. I found out later when some other work was being done on the engine that it had what appeared to be a braised spot near the pan rail. I asked the machine shop about it and he said he used Devcon - I presume its the product with the bronze in it due to it's color. Does anyone know if I should be concerned about the patch failing - not enough heat resistance?
KYWes
Jun 14, 2022 06:52 AM
camaro02DK
Jul 5, 2015 09:04 AM
Rod Bender
Classic Engine Tech
Mar 18, 2015 08:57 AM
Jazsun
Dec 29, 2014 12:14 PM
