HELP! Quick Q: How To Adjust TPS?????
Old Apr 11, 2003 | 12:34 PM
COMNBYU's Avatar
im switching to a plate set up for my n2o and last night as i put the plate in place behind the TB, i noticed that there will prolly need to be some adjusting of the TPS. is there any way to adjust this to allow a little more "slack"??
TIA, jon
Old Apr 11, 2003 | 03:33 PM
The TPS sensor doesn't affect the position of the throttle blades, or the tension in the cable in any way... it just tells the PCM how far the blades are rotated. If you move the throttle body further away from the intake, you need to adjust the cable to provide more slack, not the TPS.
Or did I miss the point of your question?
Old Apr 11, 2003 | 04:42 PM
COMNBYU's Avatar
you are correct. i thought the TPS was a fancy name for the throttle linkage on these cars. yes, that's what i need to know. how do you adjust the linkage to allow for more slack???
thanks ALOT, jon
RUENUF
Mar 13, 2016 03:37 PM
Quickss96
Jan 29, 2016 05:56 PM
plattted
West South Central
Sep 7, 2015 02:45 PM
tdigger9899
Sep 7, 2015 10:56 AM
Chevyguy358
Parts Wanted
Jul 20, 2015 07:42 PM
