View Poll Results: How you fixed your fuel smell
Replaced EVAP canister
25.00%
Replaced EVAP lines
16.67%
Reconnected EVAP lines
0%
Replaced fuel pressure regulator
0%
Replaced fuel injectors
8.33%
Replaced gas tank cap
16.67%
Tightned fuel line
0%
Replaced fuel line
16.67%
Replaced EVAP purge solenoid-valve
0%
Leaking fuel rail
16.67%
Multiple Choice Poll. Voters: 12. You may not vote on this poll
Interior Gas Smell How it was fixed poll
What fixed your problem--- Not what you suggest
I've had a fuel smell problem in my car for sometime now. I've read alot and have found this to be a common problem. I want to know what you did to fix you problem.
This is for interior and engine bay smell. Not fuel smell towards the rear end of the car.
I don't want people who have never fixed this type of problem voting
my friend had that problem with his 95' T/A, the reason was the fuel lines in the engine compartment had melted slighty and were leaking, when it was getting fixed the guy moved the line, the melted part unsealed from whatever it was touching and gas sprayed all over, good thing the car was off at that moment
If you have a gas smell get it fixed, dont need ur car to randomly go up in flames
Originally posted by 97firechicken
where can you get the canister from and how much do they cost?
Echlin Fuel System Fuel Vapor Canister
Item#: CRB220104
Price: $ 53.99
tax and shipping not included
Usually ships in 24 hours.
Attributes:
Attributes: Fuel Vapor Canister
Diameter: 5 1/8''
Length: 7''
# of Hose Connectors: 2
Hose Size: 3/16'', 5/16''
Warranty: Limited 12 Months
Comments:
. w/ OEM # 17113065
squarehead
Nov 21, 2014 08:02 PM
