Shorty Headers
I think you can do it. Have a buddy on hand to help and make sure you have all the tools. 7 hours is cutting it but it can be done. Have you ever put some in. There are certain little tricks you will find as you go along, if anything it might take long cause you will find these trick as you do it.
Good luck
Good luck
might need the help of a friend and definitely the right tools will make the 7 hr deadline a lot easier to meet. i have only installed SLP shorty headers and with a friend who has also installed a set, we probably couldnt do another in under 5 hrs knowing every step.
Yes, I will have a friend actually doing it all. He knows his stuff which is a BIG plus for me. While we are there, I am putting the NGK plugs in and I already have the wires there. And also the
white face plate air/fuel ratio illuminated gauge as well. Hopefully these headers will help me out alot with this cam I am running.
Thanks for the replys......
-Mike
-Mike
colts0455
Jul 28, 2015 11:28 PM
