Could two huge vaccume leaks cause this weird problem?
Old Mar 3, 2004 | 04:58 PM
96z's Avatar
96z
Before I put the car away for winter I was having problems with an upper RPM miss that was predictable at 5500 RPMs or so and only happened under full throttle. In the fall I replaced the plugs,fuel filter, coil, and wires. The opti was ok and only had 2,000 miles on it. I readjusted the rocker arms several times etc, still all this to no avail.
Now a week ago I was messing around with the car and when I took the elbow off there was a huge gap where I used a pert plus bottle top to seal off the inside of the old air silencer. Also upon taking off the TB gasket I noticed the gasket was torn and there was a sooty sludge built up all along the bottom of the TB and intake.
Could these two leaks be the cause of that miss?
Old Mar 3, 2004 | 05:06 PM
scoobysnax83's Avatar
definitely
Old Mar 3, 2004 | 11:52 PM
96z's Avatar
96z
Lets hope so.
Old Mar 4, 2004 | 05:04 AM
well, I'm not saying that is for sure your only problem, but probably your biggest.
Old Mar 4, 2004 | 01:23 PM
96z's Avatar
96z
Thats what Im thinking too. There is nothing left to replace AFAIK that could cause such a weird missfire.
This leak would have the potential to cause a decent powerloss also correct?
Old Mar 4, 2004 | 02:40 PM
scooters97ss's Avatar
If it was sucking a lot of air in after the MAF seems to me like it would lean the mixture out badly and cause that kind of problem.
Old Mar 4, 2004 | 03:00 PM
It definitely will. When I bought my Z it had the infamous torn intake elbow. Once I fixed that I noticed a much smoother idle and much more response and power.
Idle smoothness is gone now, lol. Heads and cam does that
Old Mar 5, 2004 | 05:18 PM
96z's Avatar
96z
Thats what Im thinking too. Especially since it only happens at upper RPM's and WOT.
Anyone else have any imput? The more people that concurr the better Ill feel.
Old Mar 5, 2004 | 05:56 PM
Spinner's Avatar
The sludge happens. It's backwash from your PCV system. IE: oil that gets past the baffles. It happens in every make/model of car. Just builds up over time, can be cleaned out relatively easily.
Old Mar 6, 2004 | 10:25 AM
96z's Avatar
96z
And this could cause a missfire???
Old Mar 11, 2004 | 03:35 PM
96z's Avatar
96z
Anyone care to respond???
Magenta_Hearts
Mar 29, 2017 08:54 PM
alex5366
Feb 17, 2015 10:43 PM
InfernalVortex
Jan 17, 2015 09:35 AM
97z28k&N
Jan 9, 2015 04:58 AM
cmdeshon
Dec 12, 2014 10:51 PM
