Tested coil with shoebox's coil test
Old Mar 5, 2004 | 01:29 PM
SLeeper94Z's Avatar
okay well i had alot of arching at my coil area last night changed the coil wire and did not change nothing , got on shoebox's page and Coil continuity test im using a handheld voltmeter, I tested each of the 4 terminals on the coil with the key on at X1k ohms
all 4 terminals got the best of 3.5 ohms does this mean my coil is shot or am i using this voltimeter right?
Old Mar 5, 2004 | 02:15 PM
TransAm219's Avatar
I would like to see the answer to this too
ttt
Old Mar 5, 2004 | 03:00 PM
SLeeper94Z's Avatar
Coil
anyone else test there coil?
Old Mar 5, 2004 | 03:09 PM
So, you got ~3500 ohms. The test was mostly put up so an open coil could be diagnosed (IOW, there would be infinite resistance).
I think my MSD coil is ~5300 ohms. I really don't know how low is too low. What kind or brand of coil is it?
Old Mar 5, 2004 | 03:27 PM
SLeeper94Z's Avatar
its the stock gm one it was on the lowest ohm setting, i just tested it again with it off the car i got 3000 ohms this time on each terminal do u think i need another one?
Old Mar 5, 2004 | 03:46 PM
I couldn't tell you for sure. I am not an electrical engineer or a coil expert. I will say that your reading seems unusual for what I have observed on a stock coil.
Old Mar 5, 2004 | 03:50 PM
WS Sick's Avatar
A shorted coil would read less ohms. Now as far as what a normal LT1 coil should read , I have no idea, but I will check mine when I get home.
Old Mar 5, 2004 | 04:01 PM
moparman's Avatar
If you have an Autozone, take the coil there. They can test it, and they have a chart with the specs.
Magenta_Hearts
Mar 25, 2015 10:24 AM
naaz90
Jul 27, 2002 08:22 AM
