How bad is it to not use thread sealant on head bolts?
i cant even remember now if i used any or not. Unless it had some on the bolts i used i didnt. Honestly i had never heard that you needed to do this till now, and ive had my engine together for over a year now, with no apparent problems.
im kinda worried now...... should i be?
Some of those bolts will go into the coolant passage and some time you can get a coolant leak out of the cylinder head bolts. If you did not use any sealent and you dont see any leaks or milky oil then I would say your fine. But it is not required to take it apart and re-do it. It is recomended to put sealent on the bolts so if there is a next time I would put some sealent on tose bolts.
Originally posted by pearlpurple
Say if a guy was very worried about this and wanted to get sealant on the bolts,, could he take them out one by one put sealant on them and put hem back in to proper tourque??
ya, what he said!
