i thought K&N didnt make this
Old Mar 5, 2004 | 09:14 PM
CamaroSS30thAnn's Avatar
well i lookedon LMperformance under new items for the lt1 fbody and i found this http://www.lmperformance.com/4176/2.html is it for real...did K&N finally do some researchg and make an SS filter...thanks just wondering
Old Mar 5, 2004 | 09:22 PM
Brent94Z's Avatar
Super Moderator
Hmm... I doubt they did but???
What is odd is the filter most use for the SS is the 33-2018 filter for the Jeep/AMC Trucks. The part number on that site for their filter is KN332118. Strange.
FWIW, I've compared the K&N 33-2018 filter to a stock SS paper filter and they share the same dimensions when holding them up to each other. So, not sure why all the hoopla about using this filter
Old Mar 5, 2004 | 09:42 PM
Muskys SS's Avatar
The jeep/amc filter will work on a SS despite all the controversy. I have one and the filter fits perfectly. The problem is that the SS airbox gets bent out of shape from the heat of the motor and the filter doesn't seal properly. In other words even the stock filter won't seal properly either.
Old Mar 5, 2004 | 09:46 PM
b-stevens's Avatar
Maybe they threw in a 1 instead of the 0?
Old Mar 5, 2004 | 09:49 PM
Brent94Z's Avatar
Super Moderator
Yeah... so when somebody orders it with a 1 that tells them to peel off the JEEP label. LOL
Old Mar 5, 2004 | 10:37 PM
97LT1SS's Avatar
Way back in '97 I spoke with some K&N folks and they pretty much said the SLP box was junk so they didn't make a filter for it. Back then I got my filter from Motorsport Technologies in Houston.
Old Mar 6, 2004 | 01:25 AM
dont really think its worth the money?? anybody think it is id rather tick with the paper one.......i was wondering about y they would make one now after 7-8 years...
Old Mar 7, 2004 | 09:47 PM
yeah i did a search ok K&N site and found nothing....i even used a search from the part number yet again nothing....what do u think LMperformance is trying to do .....
Old Mar 7, 2004 | 09:48 PM
Brent94Z's Avatar
Super Moderator
Don't know? Might want to call them and ask them. I suspect it is along the lines of what I was saying... just a method to let them know it is for an SS and not for a Jeep
Old Mar 8, 2004 | 05:03 PM
BUBBA's Avatar
The Jeep fits fine, but the holley fits better because the pleats run vertical rather than horizontal like the K&N (stiffer front to back).
I seriously doubt that K & N ever made a filter for the ram air box.
They tried every which way to get one to seal, using sealing grease, etc, but they just couldn't get their filter to seal well enough, so they just decided it would be cost prohibitive to do anything else.
The real problem is the box, not the filters. JMHO
Old Mar 8, 2004 | 05:49 PM
1996 | Z28 SS's Avatar
Originaly posted by BUBBA
I used to have the stock SS ram air on my 96 before I swapped it for the K&N CAI.
My filter pleats ran vertical... not horizontal... and it fit perfect. Let me get the part number...
33-2084
That number is right off the side of the K&N filter I'm looking at right now... my old one that fit in my SS air box no problem.. and pleats run verticle...
I also just took a look at my old air box, and nothing seems to be modified (cut or changed)
I can't remember for sure.. but I remember one time trying to put a stock paper filter made for my car from a GM dealer in and it didn't fit... I can't remember how it didn't fit though.. I think it was too tall. Not sure if the other dimensions were wrong. Hmm
EDIT - I just looked up my filter part number on the K&N site and apparently my filter only fits Dodge Rams...
All the descriptions it gives are correct about my filter (width, length, height etc...)
hmmm wtf??
Old Mar 9, 2004 | 11:49 AM
BUBBA's Avatar
Can't remember whether the Dodge ran vert or horizontal, but as I recall it was not high/thick enough, whereas the Jeep filter was.
I believe the Holley is the only way to go if you want a gauze filter. JMHO
Old Mar 9, 2004 | 12:14 PM
Holley part number???
Old Mar 9, 2004 | 12:22 PM
BUBBA's Avatar
221-5
Old Mar 9, 2004 | 02:41 PM
what the the dimensions of the stock paper element for the 96-97 SS???
The K&N is for dodge ram(fits SS)
Height: 1 in (25 mm)
Outside Length: 13.5 in (343 mm)
Outside Width: 6.625 in (168 mm)
id go w/holley but arent they blue?? i dont want blue lol
