HELP! rear calipers have locked up!
Old Mar 5, 2004 | 08:31 AM
pillagenburn's Avatar
hey guys - what would cause the rear calipers to lock up? i just noticed it today..... theyre locked and compressed on to the rotor ... no idea why this has happened
thanks!
Old Mar 5, 2004 | 09:26 AM
hot_red_z28's Avatar
is your e-brake on?
Old Mar 5, 2004 | 10:38 AM
jbird's Avatar
check for a rusted e-brake cable, or one that is otherwise kinked or bound up on something.
Old Mar 5, 2004 | 01:00 PM
rusted/kinked e-brake cable eh?
ill have to check that out
thanks!
Old Mar 5, 2004 | 01:30 PM
jbird's Avatar
hope it helps a little, not sure if that's your prob. or not, but it happened to my mom's cavalier once, cable left pulled for a while and rusted stuck, I've also heard of kinked ebrake cables. Well, hope you get it sorted out, keep us posted.
Old Mar 5, 2004 | 03:15 PM
hwo does the e-brake assembly work?
thanks
Old Mar 5, 2004 | 06:57 PM
thanks
It is just a mechanical lever that is pulled by the cable. The result is virtually the same as when you press on the brake pedal, but it just does not use the hydraulics.
Old Mar 6, 2004 | 10:11 PM
NOPE!!
im about 90% sure the rear brake calipers have seized ....
wonderful!
Old Mar 6, 2004 | 11:29 PM
TraceZ's Avatar
so you are saying that *both* rear calipers have seized at the exact same time? Time to go buy a lottery ticket.
HectorM52
Jul 30, 2017 11:46 AM
carguy0119
Apr 11, 2016 11:11 PM
HarleyZ28
Oct 5, 2015 06:23 AM
Z-rated97
Mar 29, 2015 11:17 PM
FirebirdGT
Dec 13, 2014 10:25 PM
