Stock 93 LT1 rocker arm ratio?
Old Mar 5, 2004 | 10:47 AM
Colin's Avatar
Does anyone know the stock rocker arm ratio for the 93 LT1? Was it 1.5 or 1.6?
Old Mar 5, 2004 | 10:51 AM
Fastbird93's Avatar
Same as the rest. 1.5
Old Mar 5, 2004 | 11:01 AM
Colin's Avatar
Thanks for the very quick reply
I called my engine rebuilder and he "thinks" he took .015 off the heads but he can't remember. I'm assuming I should use shimmed head gaskets?
I just don't want any piston-to-valve clearance problems..
Thanks!
colin
Old Mar 5, 2004 | 11:34 AM
Red96Lt1's Avatar
Just enjoy the higher compression ratio.
Old Mar 5, 2004 | 11:37 AM
Fastbird93's Avatar
How big of a cam??? .15 is quite a bit to be taking off. Compression is definitely going to take a hike. Did you get the combustion chamber CC'd?? That will help because you could calculate what the compression ratio would be. Don't ask, I don't know the calculation.
As for PTV clearance, general rule of thumb on a stock setup is go no higher lift than .600. So I'd say about .585 now. On the safe side.
Old Mar 5, 2004 | 02:19 PM
Colin's Avatar
Thumbs up
thanks guys.. that makes sense..
I was thinking about running a HOT cam, nothing crazy.. either that or the CC305..
I didn't CC the heads, I was running out of time and didn't bother.. whoops.. lol Great replies, guys..
this is why CZ28 kicks ***
later,
colin
Old Mar 5, 2004 | 03:49 PM
Fastbird93's Avatar
May I suggest one more thing. If you're running a 93, shoot over to www.speeddensity.ord and check it out. It's the 93 F-body forum basically. Good guys, great information to be had.
Old Mar 7, 2004 | 09:16 PM
arnie's Avatar
I don't believe you meant what you typed. If the guy took off, what he claims, he took off vitually nothin'. Well, ok, a full 2 cc. worth. Still, no need for valve contact concerns, however.
Old Mar 7, 2004 | 10:03 PM
Fastbird93's Avatar
I've never heard of anyone taking off 15 hundredths of an ince. Fifteen thousandths maybe, but hundredths, no. Just seemed like a lot to me, and it will have an affect on the compression ratio.
Old Mar 7, 2004 | 10:26 PM
Green95Z28's Avatar
I am willing to put a LOT of money that he took 15 thousandths. If he took 15 hundredths your heads would have been surfaced into the water jackeths probably. .015 is not that bad but .15 now that is a LOT to take off a head. He would have had to angle grind the intake surface or else your manifold woudn't even come close to fitting. Anyways I hope this cleared it up a bit. Good luck with your buildup and let us know how it performs!
Old Mar 7, 2004 | 10:39 PM
arnie's Avatar
Originally posted by Colin
....and he "thinks" he took .015 off the heads but he can't remember.
Is it me, that is missing something here?
Old Mar 8, 2004 | 06:12 AM
Fastbird93's Avatar
No it's me. What the heck was I thinking.
oldschool
Feb 9, 2016 09:21 PM
1775.Z28
Jan 11, 2015 10:51 AM
BIGCOWL-IMP
Dec 19, 2014 06:59 AM
Brandon Wittmer
Dec 7, 2014 12:15 PM
DubbyZ28Camaro
Aug 4, 2002 12:53 PM
