OBDI to OBDII swap
Old Mar 5, 2004 | 11:15 AM
My Red 93Z-28's Avatar
Question OBDI to OBDII swap
how hard is it to convert my 93 Z-28 to an OBDII computer?
About how much does this cost?
Old Mar 5, 2004 | 11:19 AM
WS Sick's Avatar
Quite a bit, if you go the factory swap route, youd first off need the computer, the wiring and a Maf, along with the tune. Oh forgot you'll also need the crank position sensor and the front timing cover, along with the reluctor that rides in fron of the timing chain on the crank, which makes the proper balancer hub needed.
But why would you want to do that?
Old Mar 5, 2004 | 11:25 AM
Red96Lt1's Avatar
Why the hell would you want to do that?
Old Mar 5, 2004 | 11:33 AM
i need it for tuning reasons, i can't find anyone that burns chips for my car
Old Mar 5, 2004 | 11:38 AM
WS Sick's Avatar
PCMforless.com Alvin does a very good job.
Old Mar 5, 2004 | 11:39 AM
95camaro z28LT1's Avatar
word to that
obd1> obd2
Old Mar 5, 2004 | 11:41 AM
how do i contact him
and about how much will it cost? I'm doing a 355 LT4 conversion with 30 lb injectors, 58mm TB, headers, etc
Old Mar 5, 2004 | 11:42 AM
WS Sick's Avatar
www.pcmforless.com they are 150$ for the first one, with updates added in later.
Old Mar 5, 2004 | 11:46 AM
Thanks, i didn't know what i was gonna do
Old Mar 5, 2004 | 11:48 AM
WS Sick's Avatar
Putting in a shameless plug in here for Alvin, I had a 93 T/A before my 97 and I had him burn me a chip and do some updates, and I really liked his work.
Old Mar 5, 2004 | 11:56 AM
where are they located at?
Old Mar 5, 2004 | 12:01 PM
WS Sick's Avatar
If I remember right Alvin lives in NC, but Bryan lives in Pa
Old Mar 5, 2004 | 12:03 PM
thanks man
Old Mar 5, 2004 | 12:11 PM
WS Sick's Avatar
No prob good luck !
Old Mar 5, 2004 | 12:24 PM
Valkyn71's Avatar
Not to hijack your thread, but i have a question about PCM4less tuning.
What all is changed in one of these tunes?
I had a local guy tune mine, changed fan operation temps, deleted CAGS, basic stuff. After my cam install i plan on having him change my idle speed and raise the rev limiter.
Is this all PCM4less is? resetting idle and rev limiter and such? or does he actually change the timing curve or something along those lines?
Also what would be considered a "dyno" tune?
thanks guys
