lt4 knock sensor?
Old Mar 3, 2004 | 10:14 PM
RedWS6TA's Avatar
lt4 knock sensor?
where exactly does this sensor go?
Old Mar 3, 2004 | 10:15 PM
slmdgmc's Avatar
Into the PCM. Turn it over and you will see where it goes, pretty obviousl
Old Mar 3, 2004 | 10:17 PM
pntballty's Avatar
Your PCM. Click here thx to Shoebox!! Tyler
RedWS6TA's Avatar
thanks never actually seen one just know that i need one. so pretty easy to intall i am guessing.
Old Mar 4, 2004 | 01:02 AM
KyleBlue85Iroc-Z's Avatar
Are you talking about the sensor or the knock module? The sensor goes in the block, but I'm not sure if there actually IS an LT4 sensor. The module is easily installed just like noted above.
Good luck.
Kyle
Old Mar 13, 2004 | 07:35 AM
steve-d's Avatar
when is the knock module conversion needed?
When is the knock module conversion needed? Is there a particular type of modification or HP that makes this mod worthwhile or is it recommended under all circumstances.
I'm not aware of any power loss due to "false knock" timing reduction, but possibly such a reduction of timing would be too subtle to notice.
Regards
steve
95 LT1 TA: Engine Mods
Cat Back w/ SLP muffler, UD pulley, 160* stat, Hypertech tuning & rev limit upped to 6200.
No cam No headers.
273 RWHP
Old Mar 13, 2004 | 08:17 AM
97Z-M6's Avatar
there is no such thing as a lt4 knock sensor
but there is a lt4 knock module, which is what i think your reffering to.
Old Mar 13, 2004 | 08:24 AM
steve-d's Avatar
Yes that is what I am referring to, the module. When is the conversion needed?
Regards
Steve
Old Mar 13, 2004 | 08:30 AM
joeSS97's Avatar
They made the LT4 KM to eliminate false knock from the roller rockers used on the LT4 engines.If you install roller rockers or headers you should install a LT4 KM.
Old Mar 13, 2004 | 09:11 AM
steve-d's Avatar
Great. Thanks much for the clarification.
Regards
Steve
Old Mar 13, 2004 | 09:37 AM
sfriesen's Avatar
where would you have to get a hold of an LT4 knock module at and about what would one cost?
Old Mar 13, 2004 | 12:09 PM
steve-d's Avatar
try this thread.
http://web.camaross.com/forums/showt...4+knock+module
It has all the options. BTW, the site: GMPartsdirec.com also has it for around $28 plus around $8 s/h.
LT4 knock module GM Part number: 16214681
steve
mightymouse383
Jul 20, 2016 07:34 AM
4586
Mar 18, 2015 06:31 PM
IgorT.455/406
Feb 1, 2005 06:18 AM
dreamer1q
Aug 20, 2002 11:19 AM
NJ SPEEDER
Jul 19, 2002 10:22 PM
