Fireworks from coil area!
Old Mar 4, 2004 | 07:33 PM
SLeeper94Z's Avatar
well i been trying to figure out my problems , i started the car a fews min ago and there was arching all over the place by the coil , not just the wire everywhere , even arching below my drivers side header it looked too far down to be a plug wire
is my coil just bad i thinks its the orginal, can i just get this at autozone? does it come with a coil wire?, i mean there was archign crazy everywhere anyone had this problem with a bad coil thanks
Old Mar 4, 2004 | 07:40 PM
Robs97Z28's Avatar
replace all of the wires and replace the plugs. Do not buy cheap wires or theu willnot last very long. you are in need of a basic tune up it sounds like. How many mikes are on the car since the last tune up?
Rob
Old Mar 4, 2004 | 07:45 PM
SLeeper94Z's Avatar
the wires are brand new plugs are about 6 months old, i need to change my plugs and wires because my coil is arching?
Old Mar 4, 2004 | 08:04 PM
Robs97Z28's Avatar
you stated, that there was arching down around the header area as well. I have read that alittle arching around the coil is normal, but I've never seen this for myself.
Old Mar 4, 2004 | 08:19 PM
warwickbass's Avatar
I hope there aren't any Mikes on the car since the last tune up..lol..
Old Mar 4, 2004 | 08:23 PM
SLeeper94Z's Avatar
but if its just one plug wire burnt it doesnt mean i have to swap the whole set?
Old Mar 4, 2004 | 08:26 PM
Robs97Z28's Avatar
No, you can just replace the one wire. you just didn't give much info to go on.
Old Mar 4, 2004 | 08:28 PM
SLeeper94Z's Avatar
oh, my bad lol I just want to push my car in the river as of lately
im gonna change my coil and coil wire tommorow its the stocker btw ,
Old Mar 4, 2004 | 08:39 PM
Robs97Z28's Avatar
been there....good luck! I'm not sure I would go to the trouble of changing the coil, though. it is a bit of a pita...
Old Mar 7, 2004 | 04:52 AM
craigffb's Avatar
I would say it's the coil. Had the same problem before, well maybe not as bad as yours. And the coil isn't that hard to change.
craigffb's Avatar
94Z28LS1toLT1
May 27, 2015 10:44 PM
maybe2fast
Feb 5, 2015 05:14 AM
skittlez87
Dec 29, 2014 03:24 PM
squarehead
Nov 21, 2014 08:02 PM
