Will the ZZ4 forged steel crank work in the lt1
Old Mar 5, 2004 | 09:39 AM
95Bird's Avatar
Just wondering..it has a one peice rear main..but wanted to make sure that they will work in our motors.
Old Mar 5, 2004 | 09:41 AM
KCFormula's Avatar
As long as you get it balanced I am pretty sure it will. I know the LT1 bob weight is much lighter than a regular SBC.
Old Mar 5, 2004 | 09:43 AM
dreamer1q's Avatar
Yes it will work, I run one in my car. I have often wondered why nobody else thought of using them. They are cheap, easy to find, and forged. That is a great combination
Q
Old Mar 5, 2004 | 09:44 AM
WS Sick's Avatar
I'll third it, definately will pop right in, of course get it balanced to your pistons and rods etc.
Old Mar 5, 2004 | 09:52 AM
95Bird's Avatar
good deal..thats the only thing I don't have forged on my motor. I plan on freshening it up this summer and spaying the bottom end. This crank would be great to make this thing more bullet proof.
Old Mar 5, 2004 | 03:13 PM
rmackintosh's Avatar
Yep will work fine....just put one in.....got it off of ebay BRAND NEW for $200....
he sells them on there all the time!
Old Mar 5, 2004 | 03:18 PM
lt1form's Avatar
Just wondering is the ZZ4 forged crank a 4340 steel forging? If it is, its the deal of the century.
I think like the eagle cranks (4340) are cheap but since they are for an externaly balanced engine, the balancing costs are very expensive.
Any input?
Old Mar 5, 2004 | 03:23 PM
94 NO TOP Z's Avatar
Its not a 4340 but, it is a forged steel crank. New they are a little of $500 from GM (not much less than a Scat forged 4340). But, used you see them as little as $100.
Old Mar 5, 2004 | 03:42 PM
WS Sick's Avatar
Gms steel is called I beleive 1020 steel if I'm correct. Its their own blend.
Old May 30, 2004 | 04:56 AM
dmoss69's Avatar
Will this crank hold up to 375 rwhp N/A and 575 on the bottle?
I'm in need of a steel crank now, since I broke my cast stocker last week running N/A, and I want to spray.
I'm looking for a crank and h-beam rods, I already have forged pistons.
D Moss
Old May 30, 2004 | 09:17 AM
dreamer1q's Avatar
D Moss
Holds up to 400 RWHP from me, and spins to 6900 very well. I also intend on squeezing the motor soon with a 150 shot. I trust it
Old May 30, 2004 | 09:27 AM
96capricemgr's Avatar
D Moss
The stock bottom will hold MORE than that.
Old May 30, 2004 | 09:31 AM
texlurch's Avatar
The new Eagle cranks are internally balanced.... had to cut the external balance weight off my flywheel this time around.
Old May 30, 2004 | 05:54 PM
dmoss69's Avatar
It may for some people, but I just had one crack on me with 348 RWHP with a 2000 rpm clutch dump. It amazing how others can shoot N20 and have lots of HP on thiers, but mine wouldn't take it.
Now I may have had a lemon crank, but I sure broke the stocker.
I'm gonna check that line bore also.....hmmmm
D Moss
Old May 30, 2004 | 06:07 PM
Hot Rod Hawk's Avatar
There made from 1053 forged steel. I've been running mine since 1996. its seen a 275 shot a few times and to this day bearings always come out looking great.
Low cost but you can wrap up $700 plus in crank work tricking it out but its worth it.
