correct springs with this cam...
Old Mar 3, 2004 | 11:34 AM
OsoSlo z28's Avatar
i have a cc305 cam .513/.510, so with my 1.6 rockers, that's a .547/.544. i called comp cams, and the only part number he gave me was 26918-16...$185.
my question, is there another set of springs that will fit this application, be cheaper, and require no machining?
Old Mar 3, 2004 | 11:41 AM
Valkyn71's Avatar
http://www.cmotorsports.com/93-97-fb...ine-valvetrain
Check out that link.
Old Mar 3, 2004 | 11:48 AM
OsoSlo z28's Avatar
thanks for the link.
CRN-10308-1 Crane Aluminum LT1 Head Valve Spring Kit
fits stock head without machining, good to .600" lift, includes retainers, seats, and locks $179.97
with this being a complete kit, it's cheaper. will the .600 lift be too much for stock push rods? thanks again.
Old Mar 3, 2004 | 02:47 PM
truedualws6's Avatar
You can also check out the Isky 235-D springs. I think
Thunder Racing has them. They fit the stock head w/o
modification and are good to .550"
Old Mar 3, 2004 | 02:54 PM
Daryn95Z's Avatar
CM612. They are a single spring (no machining) and are good up to .600.
They cost only $89.95 from Combonation Motorsports.
sloppytot
Feb 25, 2015 08:30 PM
Jul 4, 2005 05:00 PM
Speeds8erM-1
Aug 20, 2002 09:12 PM
Speeds8erM-1
Aug 15, 2002 10:07 PM
