oil leak from dip stick
Old Mar 4, 2004 | 07:29 PM
silverz28's Avatar
I put some dye in my oil tonight and found out I am leaking oil from the dip stick. How can I fix this. Can I pull out the dip stick a little and put some rtv aroud the edge?
Old Mar 4, 2004 | 09:28 PM
If you only pull it out a little (even if you clean the tube off), the hole will still have oil in it. RTV is not going to seal well in that case. If you were to pull the tube out and clean it and the hole, then your RTV may have a chance. Just a dab around the bottom side of the little collar should do it.
Old Mar 4, 2004 | 09:33 PM
97WS6SCharged's Avatar
It's a PITA, but if you clean the tube really well, and the area around the hole, you can reinstall the dipstick and spray a few coats of high temp paint all around it. That will usually reseal a leak, as long is it's not too big.
Don't forget to let the paint cure for a day before you start it up.
Old Mar 4, 2004 | 10:19 PM
silverz28's Avatar
Thanks for the suggestions.
warmeck
Mar 16, 2015 07:02 AM
Scottylt1
Jan 8, 2015 02:48 PM
Cam's maro
Dec 29, 2014 08:44 AM
Scottylt1
Dec 4, 2014 12:31 PM
