What plugs to use with my current setup?
Old Mar 5, 2004 | 09:58 AM
NONO5.0's Avatar
I've heard good things about the NGK TR55's and am currently running them now but I need to change them out. Here are my current mods:
'95 T/A M6 (used to be an A4)
Stock thermostat
Stock injectors
No Air pump system
Moroso cold air induction kit
AS&M 52 mm throttle body
No CAT (straight pipe)
TPIS 1 3/4 shortie headers
LT4 knock module
Ported/polished MAF (removed screen)
Flowmaster Muffler
LT4 HotCam
Ported LT1 heads
2.00/1.56 Manley race flow valves
Crower Springs, Chromemoly locks and retainers Good to .580 lift
Comp Cams screw in studs and guide plates
1.6 GM Rocker Rollers
Flow as follows:
.100 71/62
.200 133/112
.300 187/157
.400 219/185
.500 248/192
.550 258.5/193.5
Should I stick with the NGK TR55's gapped at .50 or look at another plug or gap setting?
Thanks in advance!
Old Mar 5, 2004 | 11:09 AM
Daryn95Z's Avatar
As long as your not spraying the TR 55 will work fine.
That's what I use.
Old Mar 5, 2004 | 01:30 PM
NONO5.0's Avatar
Thanks for the reply!
Old Mar 5, 2004 | 01:37 PM
CamaroBoy96Z28's Avatar
I use TR-55s too and will be sticking with them for my heads cam swap as well.
Old Mar 5, 2004 | 03:56 PM
Spinner's Avatar
Tr55s gapped to .50
Steve69SS396
Track Kill Stories
15
Aug 10, 2015 02:45 PM
Jazsun
Dec 29, 2014 12:14 PM
