Is this a problem with the Opti-spark or the tranny?
Old Mar 4, 2004 | 10:59 AM
USMuscle9403's Avatar
Hey everyone. I own an A4 1994 Chevrolet Camaro Z28 with about 130K miles. It's been a perfect car until yesterday. It starts up just fine, and is fine through first gear but when it switches to second it makes a loud clicking sound, stops accelerating *but still stays at the same speed* for about 5-10 seconds and then gradually eases itself into second. This happens whenever it wants to change gears. The car is great other than this, but I was wondering whether this was a problem with the opti-spark or does this sound like the transmission? What exactly is wrong with it? How much would it cost for it to be repaired?
Allen
Old Mar 4, 2004 | 11:56 AM
GreenDemon's Avatar
Put the engine in park and lug the gas a couple of times while the car is WARMED UP. If the engine revs freely, it's isolated to your drivetrain. If it sputters around before revving up, it's your ignition- your opti won't cause too many problems at light load, it's under heavy load especially at low rpms is where you'll see major problems.
Old Mar 4, 2004 | 02:00 PM
Thanks,
I didn't drive it after what happened yesterday, but decided to take it for a spin today after warming it up. For some reason it's running just fine now? I don't see how something like what happened yesterday could just go away? Could the heat make it act like that for some strange reason? It's never done anything like this before. I just hope it never starts up again...should I still get it checked out?
Allen
Old Mar 4, 2004 | 02:37 PM
Damnit, now it's happening again. I just took out the garbage and the same problem, but it only occured from switching from second to third and then from third to fourth. The engine revs freely when in park. What is the problem, then? How much would it cost to have it fixed?
Allen
Old Mar 4, 2004 | 03:54 PM
Anyone with any more info?
Old Mar 4, 2004 | 04:06 PM
GreenDemon's Avatar
So is the tranny slipping? Or is it just refusing to shift quickly?
Either way, it could indicate serious problems with the tranny.
Trannies don't like heat much; the problem could get more serious over time. I would either take it in now for a diagnosis or see if the problem gets any worse over the next few days.
Old Mar 4, 2004 | 04:47 PM
RENE95Z's Avatar
Just curious, have you checked the fluid level in your tranny? Start simple, then get complex.
Old Mar 6, 2004 | 12:21 PM
Here is an update on my situation...
Tranny fluid is fine. It seems that the car will run fine for a while, but then after a little while it will start repeating that same problem. Again, it hesitates at the switching of the gears, makes the loud clicking sound for several seconds and THEN switches into the next gear. I did the test that someone recommended earlier and thought that it was revving freely, however yesterday I decided to park it, warm it up and then give it quick, deep revs. That's when I heard the clicking sound once again for a split second before it continued revving. That might sound confusing, sorry...when I rev it quickly, it sounds normal for the beginning part of the rev, then makes the clicking sound, then continues to complete the rev normally. I dunno how else to put it, really. Does this sound familiar to anyone? I hope to **** that I don't need a new tranny...I can't afford it
Allen
Old Mar 6, 2004 | 02:36 PM
ttt
Old Mar 6, 2004 | 04:13 PM
SLeeper94Z's Avatar
Lightbulb tranny
hey man I changed my Ignition coil and my car seems to be shifting again! iono how there related ,well I replaced the coil today and reset the pcm drove about 3 miles normal driving not getting on it and it shifted to 3rd and 4th but I did not drive it that long or get on it but it had to do something with it I'll keep You informed if the car starts acting up again
Old Mar 6, 2004 | 06:04 PM
Awesome! How much did that cost you? My biggest fear is that I need a new tranny. If that happens, i am just going to sell my Z and try my best to find a really cheap LT1 in decent condition. You mentioned that you only drove it for about three miles, though. See, mine seems to act OK for a short distance. However, after it has warmed up it starts acting up again. I just took it for another spin about a mile up the road and back and it didn't seem bad, it only made the clicking sound and hesitated a few seconds at 1600 rpm before shifting into the next gear. I really dunno what the problem is. I was hoping that others could help me out on this because I don't want some tranny shop telling me immediately that I need another transmission and trying to rape me price-wise
Allen
Old Mar 6, 2004 | 06:17 PM
MauriSSio's Avatar
sounds like it MIGHT be the tranny. But there shouldnt be a problem when you rev it in park or nuetral. If you rev it in park and its okay,that doesnt necesarily mean its not your opti,because just revving it puts no load on the car,it might still be ignition related.
jmadoll
May 27, 2015 07:13 PM
Magenta_Hearts
Mar 30, 2015 09:42 PM
BigWil
Mar 29, 2015 12:24 PM
nballisru
Dec 14, 2014 05:01 PM
mattszm6
Dec 14, 2014 07:09 AM
