233/239 cam & AFR heads.
Old Mar 4, 2004 | 10:11 AM
Elysian's Avatar
I've got the 233/239 duration, .569"/.577", ground on a 110lsa on the way from Combination Motorsports. Question: will I have to fly-cut pistons on 195cc AFR LT4 heads? After installing this cam, does anyone know what the piston/valve clearance is @ .5?
Old Mar 4, 2004 | 04:16 PM
Denny McLain's Avatar
Based upon past experience I'd take a little clay and check the clearance if your installing heads and cam. But usually there is way way more than enough room. I'd not worry about.
Old Mar 4, 2004 | 05:08 PM
Elysian's Avatar
I had planned to check clearances anyway. I just wondered if anyone who has the cam has had problems yet? I know it is a relatively new cam, but I figure there a few souls out there running it . . .
95chwagon
Feb 28, 2015 12:02 PM
pimpss96
Feb 12, 2015 01:28 PM
MadMav
Feb 6, 2015 11:02 PM
95chwagon
Jan 13, 2015 09:19 PM
Perry93TransAm
Aug 20, 2002 11:23 PM
