Engine front cover removal
Old Mar 3, 2004 | 06:03 PM
Built on Sin's Avatar
I'm trying to remove the front cover and it won't budge. All 8 bolts
removed and the oil pan dropped. Is there something I'm
missing?
Old Mar 3, 2004 | 06:28 PM
383LT4Z28's Avatar
try using a prybar cause it could kinda be stuck to it. also make sure that you did get all the bolts.
Old Mar 3, 2004 | 07:49 PM
Daryn95Z's Avatar
Did you pull the hub off?
If you did just tap the timing cover with a hammer till it breaks loose.(Hammer fixes everthing!)
heavenly_six
Dec 10, 2014 12:23 AM
siguy
Nov 27, 2014 10:07 AM
Jul 4, 2005 05:00 PM
1LEThumper
Jul 14, 2003 12:45 PM
