Opti-spark
Old Mar 5, 2004 | 04:19 PM
96HealyZ28's Avatar
Opti-spark
Im just tryin to learn, What is opti-spark? What does it do? thanks.
Old Mar 5, 2004 | 04:26 PM
SweetZRag's Avatar
It serves 2 functions.
It sends a high resolution and low resolution signal to the PCM which determines the crankshaft position used for timing the spark.
It also contains the rotor and cap to distribute the spark generated by the ICM (ignition control module) and the ignition coil.
If there is a problem with one of the signals to the PCM, you will usually get a code 36.
It is a high failure item (especially on the non-vented models, 94 and earlier). I am on my fourth one.
It is located behind the water pump on the front of the engine and leakage from the water pump can take it out quite easily.
Did I forget anything? I am sure everyone will have something to add on this one. Except GM who should have recalled it years ago!
Jeff
Old Mar 5, 2004 | 04:51 PM
96HealyZ28's Avatar
Thanks a lot man, I appreciate the info
Old Mar 7, 2004 | 01:47 PM
SweetZRag's Avatar
Any time.
Formula Steve
Sep 19, 2023 08:31 AM
Canadian z28
May 19, 2004 06:36 AM
Dizzy1
Parts Wanted
May 1, 2004 06:07 PM
LS1-Maniac
Oct 16, 2003 04:33 AM
94DROPTOPZ28
Mar 1, 2003 02:44 AM
