Couple of rebuild questions
Old Mar 5, 2004 | 10:17 AM
Colin's Avatar
hey guys,
I have a couple of questions..
1) I'm wanting to doublecheck the shortblock assembly that my rebuilder did. I can still remove the maincaps, clean off the moly, and then check tolerances with PlastiGauge, right?
2) Does the little waterpump driveshaft have to be installed a certain way, besides the obvious keyway. I noticed that the wear pattern on mine was somewhat uneven front to rear between the two seals so I marked which side went into the water pump gear drive.
3) I had my heads milled. At what point do I need to start using a shimmed head gasket?
4) Will 1.5 roller rockers clear my valve covers if I 'modify' the PCV baffle for clearance?
Thanks! I can't wait to fire this bitch up.. couple more days
Colin
Noenav
Mar 1, 2019 07:38 AM
Sergio
Jan 27, 2016 04:27 PM
ChrisFrez
Jan 4, 2015 08:43 AM
Brandon Wittmer
Dec 20, 2014 09:51 PM
