Bad Iac symptons
Old Mar 3, 2004 | 06:17 PM
SLeeper94Z's Avatar
Bad Iac symptons
Will a Bad Iac cause your idle to jump back and fourth between
800 and 1500 rpms at idle?,could it affect shifting, loss of power, cause a miss? thanks
Old Mar 3, 2004 | 07:16 PM
HBHRacing's Avatar
sounds like IAC. could alos be a vac leak but doubtfull..
Old Mar 3, 2004 | 07:19 PM
SLeeper94Z's Avatar
but just having a bad iac cause all these problems ?
Old Mar 3, 2004 | 07:22 PM
HBHRacing's Avatar
it could cause a rough idle.. but not an all out missfire
Old Mar 3, 2004 | 07:24 PM
slmdgmc's Avatar
Mine caused about a 1800-2000rpm idle and sometimes it went down to normal, then back up to high.
Old Mar 3, 2004 | 07:28 PM
Zeueses 97 RamAir's Avatar
iac
Yes It should be throwing a code.5 somerthing try to get it scanned and find out what it is if it is idle fine then try to check your hoses goibng to tb..
Old Mar 3, 2004 | 08:29 PM
SLeeper94Z's Avatar
iat
but wii it affect shifting, loss of power, cause a miss
Old Mar 3, 2004 | 08:46 PM
HBHRacing's Avatar
Re: iat
not usualy. you could ahve several problem or like I said a vac leak.. that will effect perfromance..
also a bad IAC will not always set a code. in fact you rarely see them
Old Mar 3, 2004 | 08:49 PM
94 CAMRO Z28's Avatar
Have you tried cleaning your IAC? My idle jumped all over, especially when coming up to a stop. I cleaned it and all is well.
Aaron
Old Mar 3, 2004 | 10:38 PM
SLeeper94Z's Avatar
iat
yea i cleaned it, i tryed checking for vacuum leaks with starting fluid kinda hard to tell if there is one because the engine revs every 30 seconds, I'm going to go ahead and replace the Iac
got one ordered , i still dont think that is all my problem , will one problem create another problem?
Old Mar 3, 2004 | 10:53 PM
96ta(nick)'s Avatar
did a new iacc fix the problem? mine is doing the exact same thing and it is driving me crazy
Old Mar 3, 2004 | 10:55 PM
ChickenScreamer94's Avatar
hmmm.....I would think it is either a vacuum leak, bad iac, or the mystery idle surge that no one really can figure out.
If it is the first one, the car will only do it when it warms up.
If it is a bad iac it will be more constant, as in cold or warm.
If it is the last one, hold on My car has it, and so do a few other people on the board. Once you figure it out, call me back
I am praying that yours is the iac.
Old Mar 3, 2004 | 11:19 PM
96ta(nick)'s Avatar
mine does it when warm or cold does not matter, think i will try a new iac and see what happens.
Old Mar 3, 2004 | 11:28 PM
SLeeper94Z's Avatar
hey do your cars run like crap also loss of power and missing? along with this rpm jump
Xiantyl
Jul 21, 2015 05:42 AM
Jmj93z28
Jul 10, 2015 06:37 PM
Boss002
Jul 9, 2015 03:33 PM
colts0455
Jul 8, 2015 12:21 AM
colts0455
Jul 7, 2015 07:19 PM
