View Full Version : LT1 Based Engine Tech
- just got screwed by autoshop
- question about starting car after HOTCAM install!?!?!
- O2 Simms......
- How many hours does it take to take out and put in a new tranny in a 96 A4?
- Electric Water Pump and routing the accessory belt
- Car wont Crank...very low voltage
- Question about Jason Cromer and need a part number?
- what kind of horse power should i see
- Top dead center / timing mark is off ...?
- H2O pump w/ opti?
- AS&M Headers
- Anyone use the rear brake caliper shim to stop the squeak???
- headers or cam
- Anyone with
- 17x 11's worth it?
- Will 255/50/R16 rub up front?
- abs inop?
- dimensions of SFC's?
- Loud screech noise after car is turned off?
- Freescan will not work with 95Z
- differences between years
- Want some new exhaust any advice?
- Need Help quick with Power window!!!!
- Great service at Thunder Racing!!!!
- Failed Emissions any ideas
- 93 T56 Owners w/Gears
- What shocks to run with Eibach Drag launch kit?
- Anyone have cutout pictures?
- SLP shorties! Help!!!!
- Questions on a 383 Stroker
- turn signal and blown fuses
- Converter Troubles??
- tranny problem????
- 160* thermostat????
- starter problem...NEED HELP
- can i run 245/45/16's on stock wheels
- Header Installation
- TransAm doors on Camaros Question
- Any Idea on my Power?
- Parts list for conversion to 95+ Opti
- Those who run 396 solid roller, what dur. are you all running out of your camshafts?
- Spark Advance
- Seafoamed a few days ago and have hard cold start...
- Which FanMod Wiring is Correct for my Car?
- How much cooler with new rad?
- Hooker 1 5/8" shorties?
- What should i get for my birthday?
- how much torque does the starter put out?
- Maximum valve lift on 350 LT1
- rear main seal direction
- some sort of leak
- Tach help...
- Can someone decipher these Alignment Specs?
- Goal...0-60mph in less that 5sec. Help!!!
- Torque Converter lock up switch on the dyno?
- Need Help, Seek Opinions
- My Camaro get's hot
- 17" Rim on Convertible?
- How does a MAC muffler flow?
- Question on Kumho's 265/45/16 tire?
- Trans-Go shift kit
- not your average opti question
- Dyno Techs or Thermo inclined people IN HERE PLZ
- stock exhaust size
- left turn signal??
- i'm new here..=) and i have a question..
- SUbframe connector install help...
- signs of failing maf
- Where does this wire go to.....
- Will I need lifters?
- car finally back together onw question??
- A4 Shifter Knob
- Tach just went crazy!!
- SES, code 26, HELP ME !
- Oil leaking at block....
- What are symptons of a bad wrist pin?
- Air Dam
- Government Cap?
- Spec Clutch!
- FreeScan Help
- Need some feedback on my Ported heads
- H/C setup?
- exhaust hanger at end of trans. wont fit !!
- Mod's Needed To Beat LS1???
- How much $ to run low 13's?
- Magnaflow vs. Dynomax exhaust question
- moser good : ) ????
- pulling motor
- 355 build ????
- Best place to buy Borla??Please help!
- New LT1 owner
- 50/50 weight transfer front-back...how close are we?
- What do all the wires to the heated oxy sensors do?
- Moroso Install on 97z28...help!
- How much and what kind of forged pistons....
- Coolant light comes on...
- Cutting rear springs!
- People who did m6 conversion inside please!
- How would this sound BBK Headers with Borla exhaust and maybe cutouts!
- installing svo injectors?
- steering column
- where can I get the rear bumper for my LT1
- FelPro vs. ARP Head bolts?
- Turbo Request Today
- 9.1 1/8 = ??? at the 1/4
- jegster torque arm? anygood
- OMG Cant Drive Car!!!!
- PBR calipers, C5,LS1 calipers
- Would this be a problem with VATS?
- Water pump question
- Advancing/Retarding LT-1 camshaft
- HELP! dropped valve partially into motor :(
- Hardened Pushrods in 383
- LS1/LT1 Y-pipe ??
- Few Question on NOS and a rebuilt motor with a CC305
- valve size
- SES light on stock car
- Coil problems..HELP!!
- How do I calculate my inj duty cycle???
- Knocking noise explained inside help
- Shifter Question
- Quick Rocker Question
- Comp LT1 timing chain
- ? about carbed lt1
- A little help Please
- surging
- Simple M6 questions
- Drive shaft vibration????
- Can I get a 98+ T-56 to fit my 93?
- fuel question
- replaced tbody set ses light
- opti ?????
- quick question about coolant levels
- Code 11 ?
- Top End?
- 94 T/A turn signal trouble
- Bilstein BTS suspension package...
- Wiring for A4-M6 swap
- Got the car started.....kinda
- well, i too have the gas smell but...(long)
- Rough Idle ????
- checking ses codes-ses light off when ground??
- need help dead cylinder
- Are 93-97 Cylinder Heads the same?
- Just got 1.6 Roller Rockers but no springs...
- The T15 bolt that holds/aims the foglight is STUCK!!!
- Car Won't Turn Over...
- if i cut the exhaust pipe after cats is it legal?emition legal i mean?
- Throttle position sensor
- Starter is posessed!
- Few questions for guys without bumper supports
- Need Timing Cover Part #
- Newbie Wants Interior Pics
- P0410 code
- how high can you rev the stock bottom end without being bad on it?do have mods....
- when driving in D, I floor it and car flies, then let off gas, RMPS down, then no go
- '97 LT1 Trouble Codes
- sensor at back top of engine?
- Turbo Tune in greensboro Nc??
- WS6 PCM question????
- Autozone $120.00 Opti?
- Part # for Valve Seals??
- Adapter for K&N cai?
- Which will put out more power port LT1 or LT4?
- Copper gasket help
- PULLED HEADS...HAVE QUeSTIONS~!
- Voltage/Battery Gauge Problem??
- good posi
- Can a .5 OD be installed in a 93 T56
- Accel 300+ cured my hard starts
- Where can I find a wiring harness?
- rim and tire question
- Anyone run just straight pipes
- best place to mount accel 300+ box
- getting 18v on voltmeter
- OBDII question
- OBDII to OBDI Question - Newbie
- loud exhaust what do you guys think
- White smoke
- Stainless Steel header Q?
- Who coats LS1speed.com's headers?
- clutch ???
- gm parts
- PB Blaster & Header Install
- Starter wire
- Hi Pro MAF
- Changing the ignition module....
- Torque Arm?
- Opinions on Clutchnet or any disc
- GM parts lookup
- Does anybody have this CAI???
- Hey Shoebox...part no. please!!
- Correct opti orientation for install
- Those who protected fuel lines with duals
- T56 year ID?
- Can you adjust IAC position on stock tb?
- running rich
- Who has the tags N2OBIRD
- How do you remove air pump?
- Does Lloyd Elliot do the best port work for Lt1s?
- SBC Heads to LT1 Block ??
- Figure out this wire/connector for 5 bucks
- homemade vs slp cai?
- pics of homemade cais please ????
- 315's on a 9.5 inch rim???Possible??Suggested???
- got po400 code so i replaced egr and i still get the code??
- How much for 95 z with mods?
- Carb CAI?
- alt. reloc. brkt.
- Need part number for 1LE bellow/elbow/rubber "whatever you want to call it"
- fuel pump change
- HELP Quick! Tranny
- help w/ new autometer gauges
- thermostat ?
- What fuel filter?
- Why is this site so cheap?
- question about the y-tips on the hooker catback
- rough idling in closed loop
- Putting the tranny in??
- Exhaust setup ?: backpressure vs. low end torque
- Brake Pad Replacement?
- HELP! tranny trouble
- spec clutch question
- My valves are floating on my automatic LT1???
- Where to go for cheap editting and cables?
- Finally dynoed my LT1 SWAP!
- Use compressed air to change valve springs?
- gas smell
- My beast is alive!
- anyone know the part number for the lt4 hot cam springs?
- hotcam hp vs. cc306 hp
- pa racing chromoly k-members?
- LS1 springs into my LT1?
- A4 - T56 flywheel bolt ?'s
- EVAP can purge valve, broke plastic hose..
- MSD Has TWO WireSets for the LT1???
- Will a tranny cooler help...
- 96 lt4 Corvette redline ?
- 52 mm TB
- Comp Cam Tech Line - 1.6RRs/Coil Bind
- Loud Noise at Idle??
- AFPR question
- Should I get PCMFORLESS tuning?
- Complete engine rebuild parts list
- intake bolt location, one of the studs is longer?
- Spohn torque arm people need opinion.
- Converters
- Hooker LT from Summit?
- Visited Performance shop today
- Tube connected to the intake - weird, please help!
