surging
surging
This just started happening today while driving and especially in third gear; the car surges under 2000 rpms and sometimes will buck. The weird thing is it does it; then goes away; then does it again. The engine shakes like I have a huge cam in it and the idle is constant at 900rpm's. So the idle is perfect but the engine is shaking bad HELP?? Forgot to add that if I am spirited (gun the gas); it does not do it, only with a little load on the accelerator
Originally posted by 94F1Z28
Do you still have the EGR?If so make a block off plate for it a see if that stops it.Or check all the plug wires to see if any are burned or have come loose.
Originally posted by grygst76
I might blame the plug wires-- I will see if any are crossing each other and if not you say EGR? how do you disconnect it all?
Noenav
Apr 30, 2015 01:06 PM
