Water pump question
Old Mar 27, 2003 | 08:44 PM
big dave's Avatar
Water pump question
I recently tossed my serpentine belt and suspect that when it shredded it may have gotten between the waterpump seal. I say that because after the belt incident, I started getting a leak from the pump. It isn't coming from the hole at the bottom of the pump. I pulled if off and found the seal to be damaged. What I need to know is, is there an easy way to replace the seal and is there a gasket that goes with the seal? The seal I'm referring to is the one that goes around the rod that drives the pump. Thanks.
Old Mar 27, 2003 | 09:20 PM
There was recently a long thread about replacing the water pump drive seal and the trick to doing it without ripping the seal. Try a search for the details.
Old Mar 28, 2003 | 06:08 AM
big dave's Avatar
Thanks for the reply anyways. I'll try another search.
HectorM52
Jul 30, 2017 11:46 AM
94Z28LS1toLT1
Jan 15, 2015 07:18 PM
89 iroc zl1
3rd Gen / L98 Engine Tech
Jan 14, 2015 02:18 AM
Queens94z28
Dec 20, 2014 09:11 PM
pologreen97z
Dec 2, 2014 10:42 AM
