PULLED HEADS...HAVE QUeSTIONS~!
Old Mar 27, 2003 | 09:40 AM
lrm95transam's Avatar
Exclamation PULLED HEADS...HAVE QUeSTIONS~!
Heads came off today, and there was a fair amount of coolant resting in the pistons reason heads were pulled was to replace gasket. There arent really any signs of internal damage at all. Should i be safe just swappin the gasket and puttin her back together?
Old Mar 27, 2003 | 09:44 AM
Perry93TransAm's Avatar
Alot of the headbolts pass through the coolant passages on the block when you remove them the coolant in the block will leak into the cylenders. This is more than likely what youre seeing. I would oil my cylenders down good and turn the engine over by hand looking for visual cracks and large grooves that you can hang a fingernail on while you have it apart, then put it back together with new gaskets and youll be fine.
Old Mar 27, 2003 | 09:46 AM
what should i use to clean the inside of the cylinders? to oil em up and all? I am takin the heads themselves to be cleaned professionally.
Old Mar 27, 2003 | 09:47 AM
Rodrigues's Avatar
Whenever you pull the heads coolant will leak into the cylinders because of the coolant passage ways when you unbolt the bolts. I bet coolant poured everywhere including the ground as well, am I correct?
Old Mar 27, 2003 | 09:53 AM
I allways tun a piston to the top, put rags in the adjouning pistons to catch debris ,as well as the lifter valley, then i spray it down good with chemtool and scrub the carbon off the pistons with a brass wire brush. OIl the cylender then down with motor oil and move on to the next cylender, change the oil before starting.
Old Mar 27, 2003 | 10:07 AM
How do i raise each piston? remember that the engine is still in the engine bay. I am not that car literate when it comes to inside the motor.
Old Mar 27, 2003 | 10:33 AM
jpolz's Avatar
is the Harmonic balancer or crank pulley still attached? If so than just turn it by hand, if you can't turen it by hand a 1/2" drive socket wrench will do just fine.
Old Mar 27, 2003 | 11:35 AM
oooh yeah, good deal, i can handle that..thanks for the help
Chris Anderson
Jan 27, 2015 08:30 AM
Gtpguy
Jan 26, 2015 04:50 PM
jayblev95
Track Kill Stories
Jan 15, 2015 07:48 AM
Brad 97z
Aug 10, 2002 09:58 AM
Darth Xed
13
Jul 22, 2002 12:45 PM
