Moroso Install on 97z28...help!
Go
OK, Ok, so im having problems with something as simple as a CAI...but i just got my car and im new to working on it. First off does anyone know of any detailed instructions on how to intall it? The ones it came with are garbage.
My main problem is the black filter plate...i cant get it to fit and i dont know which way to turn it to make it fit. Oh, and do i really need to drill holes or will it work with out them? I havent gotten to the rest of it yet, because i put the stock one back on cause i had to go to work.
Any and all help appreciated.....thanks
________
ROLL BLUNTS
________
ROLL BLUNTS
Go
dang my post got buried in a hurry.............guess ill TTT it up.
________
Herbal blends for vaporizers
________
Don't feel bad, it took me more time to install mine than I would have guessed too. I had to trim outer part the filter plate to make it fit the inner fenderwell better. I did screw mine down, but I don't beleive it would move at all w/o the screws. Its a tight fit, but what isn't when dealing with these cars.
I banged on my plate for freakin' forever trying to get it to fit and never did get it right. I ended up tossing the plate to the side and clamped the filter straight to the plastic piece. It's been fine for over 15K miles that way, although I do want to get some weatherstrip or something to put over the edge of the hole that the filter hangs into to prevent it from rubbing or tearing the filter (hasn't happened yet though).
And yes, those instructions did suck...I don't know how people get that thing to fit correctly.
Ditto.... if you put the plate in the right direction, is just sits over the opening, fits loose, and needs the screws to hold it tight/help seal out the hot air above from the filter below. If it won't fit, you probably have it upside down or backwards.
As I recall... it was 8 years ago... the longer part goes "down" for the filter to connect to, and the shorter part faces "up" for the silicon connector that holds the air tube onto it.
I just let the plate lay in the engine bay. It doesn't really move around at all, it covers over the hole perfectly. What I did was, put the plate in, connected the filter from the bottom, and then connected to top plastic part last. It helps to disconnect the fuse box from its mounts and twist it up and out of the way.
Go
Cool guys this helps a bunch. I honestly didnt know whether the long side of the plate went up, or down into the hole. I got tomorrow off work, so ill let ya guys know if i get it in and everything. Thanks
________
Vapir digital air one review
________
1996LT1Z28
Apr 14, 2015 07:15 PM
GA93FORMULA
Jul 24, 2002 11:38 PM
